Go Back   HomeSeer Message Board > Security Systems Plug-ins > Security System Discussion > HAI/OMNI Panel for HS3 Plug-in (rmasonjr)
HAI/OMNI Panel for HS3 Plug-in (rmasonjr) Discussion about Rob Mason's HAI/OMNI Panel Plug-in
Closed Thread
Old September 11th, 2017, 12:09 PM
rmasonjr's Avatar
rmasonjr rmasonjr is online now
OverSeer
OMNI Plugin v3.0.2.3
v3.0.2.3 was released to the updater today. It might take a day or so before it shows up in the list.
Changes in this version:
  • Fixed - Omni buttons not showing as available in Alexa after restart (@AndrewR)
  • Fixed - Button changes to Status Graphics are not being 'saved' on a restart (Scott,@AndrewR)
Always make a backup of your system before loading a new version.
Post any issues you have with this version in this thread.
62 Z-Wave Nodes, 162 Events, 293 Devices
rmasonjr's Avatar
OverSeer
The plugin is now available in the updater...
rmasonjr's Avatar
OverSeer
This version was an emergency fix for buttons. No other changes were made.
Old September 12th, 2017, 06:17 PM
Pete's Avatar
Pete Pete is offline
OverSeer
Thank you Rob.
Updated today to Omni Plugin 3.0.2.3.
Installation logs look fine. Same one entry in logs.
Sep-12 5:15:52 PM Info Plugin OMNI has connected. IP:127.0.0.1:37948
Sep-12 5:15:52 PM Warning Attempt by plugin to register a duplicate link of Logs. Plugin: OMNI Instance:
Sep-12 5:15:55 PM Plug-In Finished initializing plug-in OMNI
Automator
Hardware | HS3 Pro - Haswell iSeries 3 - 16Gb | HS3 Lite Pine64 2Gb computers
HS3 Pro & Lite
Edition Beta 3.0.0.398 | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Amazon Echo
Security - Leviton Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Old September 13th, 2017, 09:14 AM
rmasonjr's Avatar
OverSeer
Quote:
Originally Posted by Pete View Post
Thank you Rob.
Thanks Pete - I am still trying to reproduce this on my system. It's still on my list.
Old September 13th, 2017, 10:07 AM
Pete's Avatar
OverSeer
Thank you Rob.
Curious if you see it on your system.
Here testing the Omni Plugin on the Homeseer Lite box.
Old September 17th, 2017, 04:56 PM
Pete's Avatar
OverSeer
Today ran HS3 in console mode via a terminal session (./go).
Noticed the following when I shut down Homeseer.
Beginning is startup.
03:57:12:1437:[Info]->Plugin OMNI has connected. IP:127.0.0.1:35078
Connected to HS.
03:57:12:4675:[Warning]->Attempt by plugin to register a duplicate link of Logs. Plugin: OMNI Instance:
03:54:03:7976:[Shutdown]->-------------------------------------------------------------------
03:54:03:7985:[Shutdown]-> HomeSeer Successfully Shut Down Now
03:54:03:7992:[Shutdown]->-------------------------------------------------------------------
HomeSeer Linux has shut down.
Disconnected from server - client
Connection lost, exiting
root@ICS-Pine64:/HomeSeer# Exception in LOG of OMNI: Object reference not set to an instance of an object
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) <0x7f795ca7b0 + 0x00a44> in :0
03:58:56:3031:[Shutdown]->-------------------------------------------------------------------
03:58:56:3044:[Shutdown]-> HomeSeer Successfully Shut Down Now
03:58:56:3053:[Shutdown]->-------------------------------------------------------------------
root@ICS-Pine64:/HomeSeer# Connection lost, exiting
Old September 20th, 2017, 07:55 PM
Pete's Avatar
OverSeer
Updated today from V357 to V365.
Still seeing a shutdown error after main HS3 shutdown.
06:53:15:5734:[Shutdown]->-------------------------------------------------------------------
06:53:15:5738:[Shutdown]-> HomeSeer Successfully Shut Down Now
06:53:15:5740:[Shutdown]->-------------------------------------------------------------------
root@ICS-HS3ZeeLite:/HomeSeer# Exception in LOG of OMNI: Object reference not set to an instance of an object
at (wrapper managed-to-native) System.Object:__icall_wrapper_mono_remoting_wrapper (intptr,intptr)
at (wrapper remoting-invoke) HomeSeerAPI.IHSApplication:GetINISetting (string,string,string,string)
at HSPI_OMNI.HAI.HandleRequestTemperatureAndHumidity (HAI_Shared.clsOmniLinkMessageQueueItem M, System.Byte[] B, Boolean Timeout) <0x40308480 + 0x0028f> in :0
at HAI_Shared.clsOmniLinkConnection.x1b3f2cf3fb2ff439 () <0x402d9000 + 0x00dab> in :0
at System.Threading.ThreadHelper.ThreadStart_Context (System.Object state) <0x7f708bcb1010 + 0x00099> in :0
at System.Threading.ExecutionContext.RunInternal (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, Boolean preserveSyncCtx) <0x7f708bcaf850 + 0x0016e> in :0
at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state, Boolean preserveSyncCtx) <0x7f708bcaf820 + 0x00020> in :0
at System.Threading.ExecutionContext.Run (System.Threading.ExecutionContext executionContext, System.Threading.ContextCallback callback, System.Object state) <0x7f708bcaf770 + 0x00059> in :0
at System.Threading.ThreadHelper.ThreadStart () <0x7f708bcb11d0 + 0x0002e> in :0
Old September 22nd, 2017, 10:17 AM
rmasonjr's Avatar
OverSeer
When HS3 is shutdown, the plugin is not gracefully shutting down. Most notably, it's trying to log messages related to the shutdown. I will see if there is a way to quietly shutdown.
Old September 23rd, 2017, 11:07 PM
Pete's Avatar
OverSeer
Thank you Rob.
Old September 26th, 2017, 11:26 AM
rmasonjr's Avatar
OverSeer
New version posted:
https://forums.homeseer.com/showthread.php?t=191092
Closed Thread
HTML code is On
OMNI Plugin v3.0.2.2 rmasonjr HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 22 September 11th, 2017 12:10 PM
Events using HAI plugin not working with OMNI plugin lakemirror HAI/OMNI Panel for HS3 Plug-in (rmasonjr) 7 August 15th, 2017 04:59 PM
Omni plugin won't work for us. kpeters59 HAI/OnQ Panel (HS2) 13 June 17th, 2010 12:15 AM
HAI Omni Pro II or Elk M1 Gold Plugin basshook HomeSeer General Discussion Area 1 February 8th, 2006 11:29 PM
Using the Omni plugin rod_tucker HAI/OnQ Panel (HS2) 4 September 2nd, 2003 01:04 PM
