Post here your questions/remarks when you are testing a Beta version of the plug-in
To install the latest Beta version download the zip attached to this post and unzip the 4 dlls to your HS folder. The file iTunesSpeakers.lf needs to go to your Config folder and the 2 .jpg files need to go to html\iTunesSpeakers, but they are only needed if you have never installed iTunesSpeakers before.
Changes to v1.0.0.2:
Changes to v1.0.0.1:
- Do not use WriteLogEx if this function does not exist (for HS versions older than 2.4.0.1)
- Poll speaker devices when a value is changed from HomeSeer, to be sure that the HS devices are synced with iTunes.
