I purchased the Kinect plugin last night. I had some trouble getting the SDK and drivers recognized by Windows Home Server but once they were working and the plugin installed everything worked great. I got a refurbished kinect 360 from Gamestop for $40 and had Kinect VR controlling the lights within 5 minutes. I'm not much of a scripter but there are some things that I know I need a script for. I would like to be able to control the volume on my Squeezebox radios (I already have the HS Squeezebox plugin working) and right now i am using multiple triggers to turn lights off and on. I would like to have a script that would include on and off in one script, things like that. Could anyone post any kinect plugin script examples that they think would be useful or that anyone just starting out with the Kinect plugin would find helpful? Thanks
Kinect plugin script examples
Thank you for purchasing the plugin!
Did you try the latest version (3.0.0.18) available here. In this version you can attach a voice command to any HS device without using any event or script. That should eleiminate the need for scripting in a lot of cases.
I don't have squeezebox, but I guess the squeezebox plugin creates a device to control the volume. So, from the device management screen, click on that device then go to the kinect tab, then tick the "voice command enabled" checkbox, then enter a command to control the device.
Have a look at the user guide for more details (section "device voice commands")
If you need any more help just let me know
Everything is working great. I have a Kinect attached to my HS server and another running remotely on a laptop in another room and another one still in the box. Events work as they should without scripting. Its just that I have two events for each lamp, one to turn it on and one to turn it off with Kinect VR. I just thought that with a script I could tell it to turn the lamps on or off by passing a variable to the recognition phrase (turn lamp on|off) instead of having two events for each lamp or device.
Cool!
FYI, there is currently a bug with device configuration and multi instance plugins. http://www.homeseer.com/bugzilla//show_bug.cgi?id=1673
So, if you use more than one kinect instance, this feature will only work with the first one (usually the instance without a name)
This bug should be fixed soon though.
Originally posted by kideon View PostDid the bug get fixed in the latest HS3 beta?
I also have something to fix on the plugin side
