Hope someone can help here. Just committed to HS from Vera(I have been trying this for a few days while I wait to set up a dedicated system) and have hit a snag with one blind that I cannot seem to setup/control despite all efforts reading the guides and multiple threads here. I have 5 other blinds (Louvolite, blinds0 protocol) that I can control through HS successfully. I started with RFXmnger(after turning off all other protocols other than blinds0) and can read the blind code and even control it from there like I did with the others. Sweet, that's great up to there. I then shut that down, went to HS3pro, created a device with the same code from RFXmnger, test and no response. Also tried pressing the learn button then remote buttons for the blind, again no joy. I must be missing something. Where am I going wrong?
Blinds command from RFXmnger
Packettype = BLINDS1
subtype = Safy / RollerTrol / Hasta new
Sequence nbr = 40
id2-3 = 7A0A decimal:31242
Unit = 1
Command = Open
Signal level = 0 -120dBm
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 40
response = ACK, data correct transmitted
HS3 device I used 7A 0A as above.
Sequence nbr = 40
Unit = 1
Command = Open
Sequence nbr = 40
