Hi i have a Landis Gyr E350 SMR5.0 meter, i connected the P1 interface but i get the error data is coming in too fast device update frequency is greater than last update. How can i fix this
P1 data is coming in to fast
GuestTags: None
I have exactly the same meter. When I connect with a terminal program to the com-port it works without any problem. Attached is the raw output of the terminal session. The meter send a contineus stream of data. No pauses between the data blocks. The speed is 115k2.
The second attachment is the debug output in homeseer log.
P1 terminal output.txt
homeseer P1 debug output.txt
I need to lookin to that, before I make any promises. Time is the biggest problem for now. But I do plan to support all major/standard meters.
I don't know if the old script way will work as the data will come in continuously and I expect that that will cause issues as well for the script.stefxx
Ok, it is the new DSMR 5.x standard. That is sending every second, instead of every 10 seconds.
However, looking at the code it is warning about the data, that is coming in too fast, but it should still work as expected. Can one of you confirm that that is the case? Are the devices being created and updated (every minute by default)?
If so, I only need to remove the warning and no further code adjustments need to be madestefxx
