Hello,
I'm running JowiHue 2.0.1.7, and whenever I go into the "Scenes" tab, there is one group that won't expand. Instead it sticks on "getting scenes" with a spinning wheel.
I've tried restarting the hub and the plugin with no luck. There no errors reported in the HS log that I can see.
Any suggestions on this?
- Brian
Update: There are also these errors in the log.
The "Error: (Execute):Scenedetail" always occurs after a specific animation starts. I've reviewed the animation and there doesn't appear to be any problems with it (it works properly, and the lights referenced are valid).
The "Error: (BuildSliderTabDetail)" seems to occur when trying to open the group.
Jan-08 10:29:58 AM JowiHue Error: (BuildSliderTabDetail):creativity:Object reference not set to an instance of an object.
Jan-08 10:29:52 AM JowiHue Error: (BuildSliderTabDetail):creativity:Object reference not set to an instance of an object.
Jan-08 10:27:45 AM JowiHue Animation Driveway Color Roll Finished
Jan-08 10:27:43 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
Jan-08 10:27:42 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
Jan-08 10:27:41 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
Jan-08 10:27:40 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
Jan-08 10:27:39 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
Jan-08 10:27:38 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
Jan-08 10:27:37 AM JowiHue Error: (Execute):Scenedetail: Object reference not set to an instance of an object.
Jan-08 10:27:37 AM JowiHue Start of animation Driveway Color Roll
Jan-08 10:27:37 AM Event Event Trigger "Driveway Alert Driveway Trigger"
- Brian
