After continued instability using a Z-Wave Me USB Stick I have swapped to using a Aeotec Z-Stick. However, the primary controller node ID has now changed to be node 18. This causes an issue as I also use a Aeotec Minimote that requires that the primary controller be node ID 1. Is there a way in which the primary controller can be re-numbered from 18 to 1?
Many thanks.
Many thanks.
