v3.0.2.1 was released to the updater this afternoon. It might take a day or so before it shows up in the list.
You will need to find the new plugin in the Security section of the updater. The top part of the screen will *not* show an update is available.
Before you install the new plugin, disable and delete the HAI plugin.
As mentioned here, the HAI plugin has now been renamed OMNI and has moved from beta to release version.
It is very important that you make a backup of your system before you load this version. I cannot guarantee that I didnt miss something when converting your HAI settings and configuration to OMNI.
If your system is working, you may want to hold off updating until all the kinks are worked out.
There was only 1 incremental change for restarting the plugin on a disconnect.
All other changes were strictly for changing HAI to OMNI.
This version now requires you to enter your license information. If you do not have your license handy, you can retrieve it from here or email support@homeseer.com
Post any issues you have with this version in this thread.
