I want to build a 3 channel "group" to control some RGB lights.
How do I set up a "group" called "room X" that contains 3 devices called Red, Green and Blue?
Can I still address "Red" inside "room X"?
If I "Dim" Room X, will the values be decremented evenly from their current values or will they all get reset to the closest value?
Ie What I want is it to stay at the same color when dimmed
so 75/65/55 >> dim 20>> 55/45/35
Has anyone got a script already built?
PS...I was going to use 3 x Nano dimmers as I don't need that much power, but I do need 120v dimming. All the RGB Z-wave dimmers I found are 12/24v
