I spent about 8 hours this past weekend adding support for the GC-IRE. At this point, this is an unsupported feature.
I used the following IR hardware to trigger HomeSeer events using learned IR patterns:
I am providing a few screenshots showing usage. Please post questions or comments on the IR Trigger support using the GC-IRE in this thread.
Ultrajones
- From the HomeSeer status web page, click the reconnect option for the Global Cache SERIAL device to establish a connection to the GC-IRE device.
- Press a button on your IR remote that you would like to learn the IR pattern, then repeat the button press about 4 tor 5 times.
- From the UltraGCIR > IR Triggers web page, select the Global Cache serial device that is connected to your GC-IRE, then click Update.
- If the IR pattern was learned, it will display the learned IR pattern. If more button presses are required, simply press the IR button then click update. Then simply enter the button name (e.g. BUTTON_1), then click the add icon to save the changes. Note: The pattern of some IR buttons cannot be learned for use with IR pattern matching.
- You can then use the learned IR patterns to trigger a HomeSeer event trigger.
Ultrajones
