I can't seen to figure this out... Run script seems to work OK, it runs a script at the start of the record event.
The 'Run Before', 'Run After' parameters don't seem to do anything.
Since I record off a cable box, I need to turn on my amplifier power, switch it to cable, turn on the cable box, switch the amp to cable input, change channels on the cable box, change the VCR to video input, and hit record.
A lot of this is done in the 'Run Script', which works fine.
I need something to run after the Stop event, to turn power off on all those boxes. Any ideas?
