Error after update to new version 2.0.1.0 (Solved)
    i did the update today and get this error now ?
    18-10-2017 11:58:54 ~!~JowiHue~!~Error: (InitIO):error occured during initialisation: Could not load file or assembly 'System.Data.SQLite, Version=1.0.87.0, Culture=neutral, PublicKeyToken=db937bc2d44ff139' or one of its dependencies. The located assembly's manifest definition does not match the assembly reference. (Exception from HRESULT: 0x80131040)Startup Complete, 1 errors detected, check the log for more information.
    Marcel,
    This looks like a file System.Data.SQLite.dll is already present in the HS3 installation folder. Could you check this? This file does not belong there as the plugin is expecting to find the file in the /bin subfolder. if you have it there, please remove it and restart the plugin?
    Then check if you have installed a script or plugin that installed the file there?
    Wim
    -- Wim
