How to make 2 virtual devices mirror each other?
    I have many (10) virtual devices that are tri-state devices (0,1,2 or off,on,nostate) and i'd like to be able to make another set of devices that mirror two of those states (0,1 / off,on) as statuses (used in HSTouch).
    Can someone suggest an easy way of achieving this without having to make events for each of the virtual devices.
    If I understand what you are asking, I think that this would be a great feature.
    The reason is that I would like to look at device status at different device locations on HSTouch.
    For example alarm status on both the Alarm and House Status pages.
    DSteiNeuro
    HS3Pro
    MSI Cubi Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2201 Mhz, 2 Core(s), 4 Logical Processor(s) 16GB DDRl RAM
    Enabled Plug-Ins
    BLRussound, BLSpeech, HSTouch Server, JowiHue, MyQ, Nest, Rain8, Squeezebox, Ultra1Wire3, UltraGCIR3, Vista Alarm, X10,Z-Wave
      You can do that pretty easily using the "EasyTrigger" Plugin. If you don't want to use a plugin, then you might have to write a script.
