drip irrigation zone timer valve
Are there any known issues with X10 and solenoid valves? Reason I ask is I obtained a washing machine inlet valve for use with my little irrigation system and just can't get it to play fair...I can't imagine the load is all that much from what is just really a piece of wire (thinking along the lines of what happens with CFL's?), but whilst when I switch the X10 module on you can hear something happen it definately does not open correctly and just seems to make a 50Hz hum....no loud 'click' is heard. Do some have a polarity? I originally thought not as this valve appears to be a generic style replacement.
Anyone any ideas? I wish I had the option of 12v though, I have to live with 240v!
Originally posted by Michael McSharry View PostIt does seem like you are not getting enough voltage through the coil to generate sufficient field to move the rod. Is the wiring to the solenoid of sufficient gauge and sufficiently short to not generate a large voltage drop across it?
I'm going to dig it out and have a play with it in a minute, not that I really need it now...following three days of blistering sun shine (that was our summer) it hasn't stopped raining for the past two days and is set to continue plants dont need watering now!
Originally posted by mrhappy View PostAre there any known issues with X10 and solenoid valves? Reason I ask is I obtained a washing machine inlet valve for use with my little irrigation system and just can't get it to play fair...I can't imagine the load is all that much from what is just really a piece of wire (thinking along the lines of what happens with CFL's?), but whilst when I switch the X10 module on you can hear something happen it definately does not open correctly and just seems to make a 50Hz hum....no loud 'click' is heard. Do some have a polarity? I originally thought not as this valve appears to be a generic style replacement.
First, plug the original outlet hose connection. I found epoxy and a 1/4 x 20 bolt worked well. Then remove the solenoid and rubber diaphram from the outlet side of your valve. Machine away the valve seat on the outlet side, ressemble, and it should work as required.
Frankly, I do not reccomend using these valves, as 120 or 240 volts is extremely dangerous, and should be avoided around water.
FYI, I posted a tutorial on CocoonTech on how to use sprinkler valves with your outdoor faucet to obtain a "poor man's" sprinkler system.--------------------------------------------------
**** Do You "Cocoon"? ****
