Hi mark..
I thought I would try out the new insteon plm plugin update, was not a good idea here is the error messages I'm now getting..
4/17/2011 8:50:20 AM - Plug-In - Initializing Plug-in: Smarthome SwitchLinc
4/17/2011 8:50:20 AM - Plug-In - Finished initializing plug-in Smarthome SwitchLinc
4/17/2011 8:50:20 AM - Plug-In - Interface Insteon is running as a trial, 30 days remaining.
4/17/2011 8:50:20 AM - Plug-In - Initializing Plug-in: Insteon on COM port 4
4/17/2011 8:50:21 AM - Insteon - PLM contacted on COM4 with an Insteon address of 05.EB.9E and firmware version 52
4/17/2011 8:50:21 AM - Error - Initializing interface: Insteon->The attached Insteon Interface contains older firmware and needs to be upgraded for this plug-in to operate properly. Init failed.
4/17/2011 8:50:21 AM - Plug-In - Finished initializing plug-in Insteon
I have the 2412S Insteon PLM.
I have since found out that I am not able to update the firmware on this device. Dose this mean I can not use the new ver. of the plug in, and if so, how do I get back to the old ver.
Dead in the water right now.. ( Help !!!!! )
Thanks..
Mike..
Thanks..
Mike..
