About 3 weeks ago I installed 2 new Leviton light switch, unplugged my Aeon Z-Stick Z-wave USB adapter-S2 from the pc, turned it into add mode, then I activated both new switch next to it, the blue light turned solid for both and addition was successful.
Yesterday I basically tried the same, installed 2 new Leviton switch, activated the "add mode" of the USB stick but now, it just doesn't react when I activate any of the new switch.
Was wondering if the new switch were the problem so I went back to one of those I installed 3 weeks ago, I set the key to "delete mode" I successfully removed one of the 2 switch, but now I can't even add back this one!
Do you think I have to replace my usb stick? If I should, which product should I buy? I would really like to get something you can backup because re-adding all nodes to a new key sucks...
Thanks a lot!
Thanks a lot!
