SDJ-VStat General Description
Steve
- A Virtual Thermostat plug-in for HS3. The Virtual Stats use any temperature sensors and switches within HS3 to monitor and control devices.
- Any number of VStats can be setup, within the single plug-in, which can theoretically use any temperature sensor devices for input and control any switching devices.
- VStats can be heating or cooling stats.
- Multiple sensors can be selected for each VStat which can be configured to use the Lowest, Average or Highest of the sensor temperatures.
- Each VStat has Day(High), Night(Low) and Away(Frost) SetPoints which can be renamed as desired.
- Each VStat has a 7 day schedule to automatically switch between Day and Night SetPoints at 15 minute resolution.
- The target temperature can be temporarily raised or lowered manually as well as toggled between High/Low SetPoints.
- Away(Frost) mode will interrupt the schedules and set the target temperature to the Away(Frost) SetPoint until Auto is reselected.
- Boost mode will force the heating/cooling to On for a period of time in 15 minute increments. The increment is configurable.
- There is a separate (windows only) program for quickly creating and editing 7 day schedules for the VStats although they can also use schedules created and edited in the excellent EasyTrigger plug-in.
Steve
