Having trouble with values and strings....
    I am missing something.... Got my device (current temperature), string and label set up like I THINK it should be, but I get NOTHING. "The Current Temperature is : "
    See Pics.
    What am I doing wrong?
    For me, there is some unknown special combination of initializing the device using the sign's INITIALIZE link just below the sign's name in the plugin management page. From there, it needs a soft reset, and maybe something else to set the page sequence if it isn't set already.
    huggy_d1
    Automating made easy
      Make sure you set the appropriate size of the string label so that the value of the device string will fit in memory. These BB are very sensitive to memory. After you set the memory for the string label you will need to initialize the BB
      Cheers,
      Bob
        Is there an event action to init a sign?
        huggy_d1
          I don't think there is.
          Add a feature request on my site
          Cheers,
          Bob
            Added.
            huggy_d1
              STILL with the string issues....
              OK, so I have made sure I have all the correct syntax (and I am using the correct brackets!) and everything worked! .....at first. I am just trying to show the temp and heat index. I initialized the sign and the correct information showed up on the sign. Later in the day, the sign still showed the same info so I checked all my BLLED stuff again. That's when I noticed the attached. Instead of having the correct string info of [devicestring=W1|update=onchange] it instead said "79".
              I am using the latest BLLED from the updater.
              Any ideas?
              Rob
                Any ideas?
                Rob
                I had the exact same behavior today while troubleshooting why I cannot get the device value or string to appear on the BB display no matter what I do.
                I can program and display messages on demand.
                Just nothing related to true automation here without resorting to a script.
                Is this the way it is supposed to work? What is the magic handshake to make it work?
                huggy_d1
                  I have the exact same problem, i.e. if I use [devicevalue=B2|update=onchange] in a string, it works maybe once or twice, then it stops updating, and the string in the config page is replaced by the last value.
                    help desk ticket submitted
                      Yep. I will have a look as soon as I can and let you know
                      Cheers,
                      Bob
                        string replace with actual device value.
                        This is still an issue. If a fix is not possible, how is everyone working around it.
                        Larry
