I posted 1.0.19 to the HS3 updater
BLLED is in development
Originally posted by Blade View PostOK I will take a crack at it
For running the plugin remotely:
You will need to have the HS3 folder structure on your remote machine because it will use those paths to write the settings for the plugin. The plugin will check for these paths and if they do not exist it will not run.
Here are the paths you need: (they must match your main HS structure)
[HS root]
[HS root]\BIN
[HS root]\Config
[HS root]\Data
1. Copy the following files to [HS root] on your remote machine:
HSPI_BLLED.exe
HSPI_BLLED.exe.config
HomeSeerAPI.dll
HSCF.dll
Scheduler.dll
2. Copy the following files to [HS root]\BIN\BLLED on your remote machine:
betabriteusb.dll
3. You will need to run the plugin as follows from the [HS root] folder on your remote machine
HSPI_BLLED.exe server=[ip address of your main HS3 machine]
Cheers KenHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by Blade View PostActually I have not run any plugin remotely LOL
This is the first time for me too.
Not sure if you can have it running on the main HS machine as well.
HSPI_KINECT.exe server=192.168.1.9 instance=<name of instance> autoreconnect=<time to reconnect in seconds if disconnected>
just thinking that HS would some how need to know what instance the sign was on to send the correct message to the sign
CHeers KenHSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Blade,
I am still only able to send text to label A none of the other ones work
Originally posted by outbackrob View PostThere is LEDAM! It is awesome! Works like a champ. Have had it running 4 signs for years. The REMOTE sign feature is no longer working for me, but the rest of it is fantastic. Feature rich and easy to set up.
Rob
Played a bit today with Snevl_BB and now would like to try LEDAM. Latest vers I've found so far is 1.0.66, dated Feb 2008. Is that the latest or was there further development?Real courage is not securing your Wi-Fi network.
Cheers Ken
You must set the sequence as well
Originally posted by Wadenut View PostThanks for the lead Rob. For the time being I'll be parked on HS2.
Although I doubt if I will be doing any major changes to it, I'm still supporting Snevl_BB, and use it myself on my two signs. If you hit any snags, just give me a shout.
I'm really glad Bob has taken up this project so HS3 will have something to handle the signs.
Steve
Originally posted by sparkman View PostStrangely enough, I did get one sign working properly again for a few minutes this morning after initializing with just "B" as the sequence and then adding text to A and C after. However, I tried the other sign right after and could not get it working using similar steps. I then went back to the working sign and messed it up again to where it just displays the A text....
Cheers
Al
AlHS 4.2.8.0: 2134 Devices 1252 Events
Originally posted by Blade View PostIf you want A and C to show then you need to add another action called "Set Sequence" and set it to ACLast edited by kenrad; June 12, 2014, 07:01 PM.HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
Originally posted by sparkman View PostHi Bob, updated to .20 and all is working again. Did you figure out an issue or is it just coincidence?
Al
The pictures are still being stubborn. Sometimes they work and sometimes not
Originally posted by kenrad View PostBlade I tried that but no matter what I try it is only letting me set messages to A
Make sure you are running 1.0.20 and try this script and let me know what it does:
Code:Sub Main(ByVal param As Object) hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "A", "Test 1"}) hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "B", "Test 2"}) hs.PluginFunction("BLLED", "", "SetMessage", New Object(){1, "C", "Test 3"}) hs.PluginFunction("BLLED", "", "SetSequence", New Object(){1, "ABC"}) End Sub
