I can change the values in the Device Management area. It makes the status changes on the HS web server, but those changes don't seem to replicate to the Denon. Additionally, if the BLDenon plugin is running and I send a command through it, the Denon's built in website no longer responds or refreshes unless I disable the BLDenon plugin. It is like it is DoS'ed by the plugin with commands it can't successfully process.
Should I be setting the plug in to port 80 or port 23? Any ideas what could be going wrong? I'd really like to buy this plug in because I can control all the AV things (ex. Roku) through the wall except for this piece. Also, it is better to leave the RaspberryPi's at ~95% volume and adjust the amp. There is less distortion. This plugin would allow that.
Much thanks,
Raymond
Much thanks,
Raymond
