At home? Away?
    At home? Away?
    So, how do I set up HS to know that I'm at my house, or away?
    I was thinking that I'd use BLRouterMonitor to check if my smartphone is connected. Or, is there another method?
    Take a look at PHLocation and set up geofences. I've found it pretty unreliable to monitor a smartphone as they tend to go to sleep and not respond to pings.
    Sent from my Phone using Tapatalk
      I just use no motion for x minutes
        I use my alarm system. If it is "armed away" then we're not in!
        Nicolai L
          That's my way as well.
            As said, if you have an alarm system which HS can monitor, use it.
            Myself, I use motion by tracking the last motion sensor activated. If the last one happens to be the one at the door, which has a short Off time, I set away when it turns off. This has never failed me and it's completely automatic.
              I do mine on the basis of door locks (if locked from the inside or outside) and time of day.
              I wanted to use IFTTT and smartphone position, but I find the reports from it to be too sporadic (probably because the smartphones go to sleep).
                I use my alarm system as well. I find that the motion sensors attached to the alarm, work far better than the z-wave motion sensors. Also, the alarm has door and window sensors which are great for event triggering.
                - Robert
                  At home? Away?
                  I've been using a combination of PHlocation and jon00's network monitor for years. Works like a charm. A device joining the wifi occasionally happens before PHlocation has updated a device to Home, to switch the silent alarm off. You'll see what I mean. With location tracking you can control heating when near home too (without buying a nest).
                  Both are free and VERY good.
                    At home? Away?
                    I also have very poor reliability from the IFTTT. I really can't use it for anything.
                    For Occupancy I use a hallway motion sensor. The first time it is triggered it sets a "someone home" flag. The flag gets reset every day at 3AM. I use this as a condition of almost all my lighting and HVAC events.
                    Steve Q
                      I use a combination of everything:
                      PHLocation
                      IP Pings from Ihpone
                      the best is Hallway combined with main door sensor: if door is set to close and no PIR triggers whint the next 60 sec. we must have left via the door.
                      PHLocation is great for incomming and leaving events.
                      Steve Q
                      Best,
                      Jakob Sand, I automate everything!
