** This is now in the HS3 updater **
This plugin will allow you to interface with your Roomba 980
Consider this BETA
Right now it will just receive data from the Roomba and update devices. You can also control the roomba from the root device
NOTE:
You will need to know your username and password for the Roomba. I was able to get this using the dorita980 package on my Raspberry Pi
Installation
Download BLRoombaWifi
You will have to manually unzip the files to the proper locations:
HSPI_BLRoombaWifi.exe - copy to HS3 root folder
HSPI_BLRoombaWifi.exe.config - copy to HS3 root folder
M2Mqtt.Net.dll - copy to [HS3 root]\BIN\BLRoombaWifi (you will have to create this folder)
Newtonsoft.Json.dll - copy to [HS3 root]\BIN\BLRoombaWifi (you will have to create this folder)
Restart HS3 and enable the plugin
Consider this BETA
NOTE:
Installation
