HomeSeer either needs to hire a good technical writer or farm out the job. In face there may even be some on this board that have done technical writing that might be willing to do the job either for money, barter or both.
!!! JUNK !!! (***SOLVED***)
HomeSeer Version: HS3 Standard Edition 3.0.0.548
- Likes 1
Originally posted by MrMxyzptlk View PostYou got it! I saw that you joined here a year or 2 ago...HomeSeer Version: HS3 Standard Edition 3.0.0.548
Beta Build with DB changes
Rich posted a beta yesterday that included a change in how often data is written to the database.
https://forums.homeseer.com/showthread.php?t=181241
Originally posted by macromark View PostRich posted a beta yesterday that included a change in how often data is written to the database.
https://forums.homeseer.com/showthread.php?t=181241HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Not True (I've been in HA 30+ years ,, those days there was nothing but X10..) My HS2 system is still running today ,, read above , My hs2 system is a buggy Dell box..
Worked with thousand of software packages (Including multi million dollar LIMS , ACAD , MCAD , MANMAN , NETWORK, 123 , OFFICE , BASIC the list goes on and on..) never have I worked with a piece of software that restarts itself after a clean shutdown !!
Most are more stable than HS3 is today....
Originally posted by MrMxyzptlk View PostHomeseer is NOT for newbies! Homeseer is NOT professional software (straight from the main devs mouth), Homeseer is buggy at times, Homeseer is the (combine all the following), BEST, MOST DIVERSE, CONFIGURABLE, home automation software out there.
Trust me! I have used literally EVERY home automation software / hardware system over the last 10 years in an attempt to find Nirvana...there is NO SUCH THING.
Some are BETTER, but may cost $100,000, some are more stable, but you are locked into their hardware and limited devices, some are less expensive, but don't work well at all...Last edited by dem5867; June 9, 2018, 07:36 PM.
I don't think the dual nice has been fixed (Or at lease correctly..) I had to move the devices on my second NIC / Router because my Insteon hub has been disconnecting every couple of hours,, now that I moved it to NIC 1 and deleted NIC 2 the Insteon hub has not disconnected in over 24+ hours..
Originally posted by ServiceXp View PostWow, I have to say you must be the luckiest man in the world. I can 100% guarantee a corrupted HS3 db after the 2nd attempt on my system.
When HSSentry was not seeing HS on the correct adapter (before we had a solution for multiple adapters) and would kill HS3, the db corrupted every single time, it was a 1 to 1 corruption cycle.
The power company bailed the other day ,, yet I did turn off the write caching for the SSD now the system is running as slow as some XTs I used , not a 4 core AMD..
My DB still appears to have issues some devices got lost and now that I put them back my events list those devices as ID doesn't exist...
After removing the second NIC , I'm now getting this error with the updater,, "Please wait for the updater control file failed to be downloaded or parsed.",, Anybody know how to cure this issue ???
Originally posted by Monk View PostThe whole thread designed to generate conversation - likely started by a HS shill. Participants have too much time on their hands.
You're kidding right? You think we started the thread?
Originally posted by MonkThe whole thread designed to generate conversation - likely started by a HS shill. Participants have too much time on their hands.Originally posted by macromark View PostA shill, also called a plant or a stooge, is a person who publicly helps or gives credibility to a person or organization without disclosing that they have a close relationship with the person or organization. ...
You're kidding right? You think we started the thread?HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by macromark View PostA shill ...
You're kidding right? You think we started the thread?Mike____________________________________________________________ __________________
Originally posted by Uncle Michael View PostHW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10: Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
