Hi Spud,
Quick question. Messing around with Outputs into a Sainsmart relay module. Configured a pin for output and the relevant device was created. However, I've run into a very minor issue with the default device setting.
When I select OFF on the device in homeseer, the relay is ON, and when I select ON in Homeseer, the relay is OFF. The device status by default sets 0 = Off and 1 = On.
I have got round the issue by settings the device 0 = On and 1 = Off.
Is this OK or is there another way I should do it?
Many Thanks
Many Thanks
