I do want to use HS as a surveillance system (I already have a Hikvision NVR) but I would like to be able to access cameras feeds for real-time view and when I am away from home.
All cams are POE IP ones and they are all onto the same network as the HS computer.
I don't want to open any ports into my router to avoid security issues and I think MyHS service might be way to go.
Do you think there is a way to access cameras via MyHS? Is there a plugin that can help without overloading the HS3 computer?
Thank you
Thank you
