Setup:
I have a 6 button Keypad that controls a Fanlinc as follows: Fan High(Btn3), Fan Medium(Btn4), Fan low (Btn5), and Fan off (Btn6). The Insteon plugin links in the Keypad are correct and "Sync linked responder devices" is checked. Everything works as expected when operated from the keypad. For example Btn5 turns off other keypad button lights and the fan comes on at low speed.
Problem:
Problems occur if I activate a button like Fan low from the HS device view or voice command. First I see the Fan low (Btn5) light up, but Fan off (Btn6) does not turn off. Also the fan always comes on at high speed (Happens no matter what speed is selected). Judging from your response here you support this functionality. I have 5 fanlinc/keypad pairs in my setup with same issue, which reduces the chance of a typo or communication issue. Perhaps an alternative is to use groups, but that adds a lot of clutter, confusion, and work.
Debug:
Attached is the detailed HS log from both the direct keypad "Fan low" press (works) and the indirect HS view "Fan low" press (broken). The logs seem to indicate the correct actions are being taken in both cases. In the direct keypad case a value of 33 is written to the Fanlic, whereas for the HS btn the new value is not logged (Perhaps it is incorrectly 100). I am using the Insteon 2245-222 for which direct logs are not available.
HS3 Pro Edition 3.0.0.368
Insteon plugin v3.0.6.0
Problem:
Debug:
