Thanks for the feedback
There are 4 different possible commands to arm a partition (see API doc)
but I'm not sure to understand if command 032 and 033 work as Away or Stay mode.
The Arm button on the status page uses "Partition Arm Control - With Code (033)" and is supposed to work as if you were entering your code from the keypad. I should probably add "Arm Away" and "Arm Stay" buttons on the status page.
The 4 commands are available as EnvisaLink Actions from Events. So next time you get some time to test this, please try to set up some events to test these actions.
Regarding the code, the config page says master code, but actually you can set any valid user code and it should work the same.
- Partition Arm Control - Away (030)
- Partition Arm Control - Stay (031)
- Partition Arm Control - Zero Entry Delay (032)
- Partition Arm Control - With Code (033)
