Do you have the option to add it with out security.
Unable to add Linear GD00Z-4 - Security Scheme issue - working!
Tried w/o security as well. It does not see the devices.
Tried w/o security as well. It does not see the devices. Import is successful, but when i try to fetch additional functions by selecting device, it does not see it.
The only other thing is , I had updated my ZStick with latest firmware. http://aeotec.com/z-wave-usb-stick/1...-firmware.html Not sure if that made a difference.
Originally posted by Rupp View PostDo you have the option to add it with out security.
Works with SmartStick+
I replaced my Aeon ZStick with HomeSeer SmartStick+ and it seems to be working now. Not sure why Aeon stick would not add GD00Z-4, but glad that smartstick+ is working
Originally posted by sukrit007 View PostHS3 ZEE Edition 3.0.0.208 (Linux) with Zwave 3.0.1.29 . Do not see option to upgrade zwave plugin though.
As mike said.
I've noticed that adding security devices is far easier with z-net/z-stick+ compared with the older z-sticks. It's still not problem free with the new controllers, but easier.Tom
Guest
Any updates on this issue? I've run into the same situation with the same GD00Z hardware... Initially I received an older unit from Amazon (it still said Linear on the opener/product box) but I RMA'd that one and received a newer unit that is H/W Rev B and R/W Ver 2.1 (with the GoControl logo on the opener/box). It will add the device as "Sigma Entry Control" but no child objets associated with it. Logs show this when trying to re-scan:
Z-Wave Error Security class information is NOT present - cannot continue loading node 35
Hoping it's not some compatibility issue with the Aeon Z-Stick....
Originally posted by FarSide792 View PostAny updates on this issue? I've run into the same situation with the same GD00Z hardware... Initially I received an older unit from Amazon (it still said Linear on the opener/product box) but I RMA'd that one and received a newer unit that is H/W Rev B and R/W Ver 2.1 (with the GoControl logo on the opener/box). It will add the device as "Sigma Entry Control" but no child objets associated with it. Logs show this when trying to re-scan:
After several times trying and it failed, deleting node from the View Device management page , I tried on Z-Net controller page and selected action "remove/exclude node", then on the lock started the pairing process again on it. The log showed action.
Node was removed.
Then tried again from action selection selected add/include node.
and it worked adding the lock completely.
