CLOSE, BUT NO CIGAR!
    Good day.
    Noob UltraCID user.
    Got a Dell Conexant USB Modem which installed fine.
    I can interrogate the modem using PuTTY no problem.
    It detects on hook/off hook and ring but never reports the CID.
    I send the following commands via PuTTY and get these responses:
    ATZ
    OK
    AT+VCID?
    0
    OK
    AT+VCID=1
    OK
    AT+VCID?
    OK
    AT+FCLASS?
    0
    OK
    AT+FCLASS=8
    OK
    AT+FCLASS?
    8
    OK
    Diagnostic dump form Device manager:
    ATQ0V1E0 - OK
    AT+GMM - +GMM: V90
    AT+FCLASS=? - 0,1,1.0,8
    AT#CLS=? - COMMAND NOT SUPPORTED
    AT+GCI? - +GCI: B5
    AT+GCI=? - +GCI: (00...string of HEX deleted for readability)
    ATI1 - OK
    ATI2 - OK
    ATI3 - CX93001-EIS_V0.2002-V92
    ATI4 - OK
    ATI5 - B5
    ATI6 - OK
    ATI7 - OK
    Could this be a driver issue or do I need to customize the modem initialization strings?
    Running Win 7 HS3 Pro
    Many thanks if anyone can help! Looks like a great plugin if I can get it to work.
    Rob in Maine
    Hello Rob, yes, this could be a driver issue. However, I have also experienced issues where a modem wouldn't output caller Id even when I used the manufacturer's drivers. I have always had the best luck with the drivers Windows installs when you insert the USB modem into the computer.
    Ultrajones
      Thank you UltraJ!
      I am migrating to a brand new Dell box (Win 10!) and will install the ancient Homeseer PCI Modem to see how that works.
      Like your plugin a lot.
      Rob in Maine
        Hello,
        Bought one of the "USB FAX MODEM CX93010" just as you did and am running into the same issue being that I can detect ring but no CID output.
        Were you able to get this going and what did you do?
        The lights on the modem, did they light up at all or show activity?
        Charlie
        HSPro: 3.0.0.194
        PL: Insteon PLM 3.0.5.20,Insteon Thermostat 3.0.1.1 , UltraM1G, RainRelay8, UltraECM3, UltraPioneerAVR3, BLBackup, weatherXML, Jon00 Network & PC Monitor
        HW : Win 7 64bit, Intel i7-2600, 16 GB DDR3 Ram, 60 Plus Insteon Dual Band Devices, Rain8 Pro2, Elk M1 Gold, Brueltech GreenEye.
