Dear Spud,
I have your plugin in trial mode. I have 4 Nest protects, and no Nest Thermostat. I try to change the mode manually from Away to At Home, but see the following error in the logs:
Sep-20 01:43:46 Nest DEBUG data: null
Sep-20 01:43:46 Nest DEBUG event: keep-alive
Sep-20 01:43:27 Nest DEBUG System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: Response status code does not indicate success: 400 (Bad Request). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at NestSharp.NestClient.SetAwayMode(String structureId, Boolean away) at HSPI_Nest.NestApp.ButtonPress(String buttonName, Double value, Int32 dvref) ---> (Inner Exception #0) System.Net.Http.HttpRequestException: Response status code does not indicate success: 400 (Bad Request). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext()<---
Sep-20 01:43:27 Nest ERROR One or more errors occurred.
Sep-20 01:43:27 Nest DEBUG PUT: path=structures/XGftsFJcgRyBSpN8t6W5wNeW9ysPmUe_eWJYTSXZ9wr3Oyz3qeBAHw payload={"away":"home"}
Sep-20 01:43:27 Device Control Device: House Nest St Peters Avenue to
The plugin is otherwise working. Can you help me understand what needs to be done?
Kind Regards,
Nick.
Kind Regards,
Nick.
