The plugin works fine for me but it seems to break the Blue Iris plugin that i am also running. From what I under understand it has to do with Newtonsoft.Json.dll being placed in the root of the Homeseer folder rather than with the plugin. Is this something that can be changed for better compatibility?
Nest plugin Newtonsoft.Json.dll location.
All the dependencies for the Nest plugin (including Newtonsoft.Json.dll) are installed in bin/Nest, not in the root Homeseer folder. If you don't see Newtonsoft.Json.dll in bin/Nest then reinstall the plugin.
You can delete Newtonsoft.Json.dll in the root folder if you have one, the Nest plugin wil still run fine.
