When I try to set (for example) the lower target temperature higher, I most of the time get a 429 HTTP error, which translates into "Too Many Requests".
Here is the full error from the log:
Apr-03 0:30:30 Nest DEBUG System.AggregateException: One or more errors occurred. ---> System.Net.Http.HttpRequestException: Response status code does not indicate success: 429 (Too Many Requests). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext() --- End of inner exception stack trace --- at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at NestSharp.NestClient.SetTargetTemperatureLow(String thermostatId, Double target, String scale) at HSPI_Nest.NestApp.ButtonPress(String buttonName, Double value, Int32 dvref) ---> (Inner Exception #0) System.Net.Http.HttpRequestException: Response status code does not indicate success: 429 (Too Many Requests). at Microsoft.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSu ccess(Task task) at Microsoft.Runtime.CompilerServices.TaskAwaiter.HandleNonSucc ess(Task task) at FirebaseSharp.Firebase.d__3.MoveNext()<---
Apr-03 0:30:30 Nest ERROR One or more errors occurred.
Apr-03 0:30:29 Nest DEBUG PUT: path=devices/thermostats/gi6tL1If6GjVbuvSpAmA_A_VumSUMP-v payload={"target_temperature_low_c":21.5}
Apr-03 0:30:29 Device Control Device: Nest Target Temperature Low to + (1001) by/from: CAPI Control Handler
