I put this post in an old thread but thought I would ask it here as well. I use an ASP page to get the PIR on my Axis camera to trigger an event in HS2. However, it doesn't work in HS3.
Based on some searches, it's not clear whether ASP is supported in HS3? This post by Admin says that "classic" ASP isn't supported however I don't know enough to tell the different between classic ASP, ASP, ASP.net or ASPx. I think ASPx = ASP.net.
So would converting this code to ASPx/ASP.net work in HS3?
dim msg
msg = Request.QueryString("Message")
If StrComp(msg, "comp_camera_motion") = 0 then
hs.triggerevent("GotCompMotionEvent")
End If
dim msg
End If
