Any chance the new hub is supported by your plugin?
Are you supporting the new Hub (version 2)
Yes, but i'm not really sure what it has to offer over the old one regarding my plugin.
I need to write a new driver. No timeframe yet.Last edited by mnsandler; December 16, 2014, 06:20 PM.Mark
HS3 Pro 4.2.19.5
i have been able to initialize the hub2, register devices and control them. I need to retest the groups
reading the database links doesn't seem to respond (not a big deal). I have a query into smarthome on this.Mark
HS3 Pro 4.2.19.5
Hub 2 not working for me
I just purchased the Hub version 2 and cannot get logged in to the unit through the plug-in. I am putting in the IP+25105 port -- no joy. States interface is protected. I also cannot get logged in through just a web interface. The Insteon App on Windows 8.1 works though. I have not opened ports (25105) on my router yet -- thinking that this should not be required.
I went back to the USB 2413/PLM. Just trying the Hub 2 as an alternative.
Bleeding the edge with HS3 Pro Edition 3.0.0.147 (Windows) with Insteon (Mark -- I will call your version Professional) 3.0.5.10.
Originally posted by dmauer View PostI just purchased the Hub version 2 and cannot get logged in to the unit through the plug-in. I am putting in the IP+25105 port -- no joy. States interface is protected. I also cannot get logged in through just a web interface. The Insteon App on Windows 8.1 works though. I have not opened ports (25105) on my router yet -- thinking that this should not be required.
no need to open the fw port
make sure you have the correct IP, ping it, and then use a port scanner to check to see if 25105 is listening.
if all else fails, factor reset the hubMark
HS3 Pro 4.2.19.5
Guys,
I just had a call with SH, turns out I'm not ready to support the Hub 2 fully. I don't have a timeframe yet.Mark
HS3 Pro 4.2.19.5
guys,
if you are still having issues registering devices with the Hub2 please give 3.0.5.51 a tryMark
HS3 Pro 4.2.19.5
I got the Echo and Hub pair when SH offered the Hub for free (though it took a month to get them both because everyone else wanted in on that deal, too). I wanted to be able to have always-on voice control and it works fine (controlling the Hub with Alexa). Of course, I just found the skill for myHS integration. I tried it last night and it was iffy: it worked sometimes and not others.
Anyway, my question is about the Hub v2 vs. my serial PLM. Is there any reason to use the hub over the PLM? I have not configured Mark's plug-in to use the hub, so HS doesn't know anything about it. Are there any features to be gained or lost if using the Hub instead of the PLM? I hadn't planned on swapping out the PLM for the Hub, but I thought I would ask in case there is something to be gained or for you guys to say, "No, don't do it! The world will end!"
Scott
Originally posted by sbueffel View PostI got the Echo and Hub pair when SH offered the Hub for free (though it took a month to get them both because everyone else wanted in on that deal, too). I wanted to be able to have always-on voice control and it works fine (controlling the Hub with Alexa). Of course, I just found the skill for myHS integration. I tried it last night and it was iffy: it worked sometimes and not others.
ScottMark
HS3 Pro 4.2.19.5
