THGR810 / RFXrec433 stops
    BLRADAR is using aW800Rf32 on Com 5 and RFXrec433 on Com 8. The temps sensors stop receiving updates periodically. I suspect there is an issue with the RFXrec433 but nothing is reported in the HS log. I shutdown the PI and reenbable. The PI reports connecting to the com ports but no other issues. How can I troubleshoot this?
    Larry
    I know it’s an old post, but I’m having same problem. Disable then enable the blrf plugin takes care of issue for 6 hours to 36 hours, but then it happens again .
    Any advice on troubleshooting would be appreciated
    Regards,
    Andrew B.
      What serial port control type are you using in the plugin on the options page
      Cheers,
      Bob
        Didn't think it was selectable for the RFXCom..
        Should I change one of the ones below?
        Click image for larger version  Name:	BLRF config.png Views:	2 Size:	101.5 KB ID:	1247164
        Regards,
        Andrew B.
          Yes it is static for the RFXCOM receiver
          Do you think you can capture the issue with debug logging turned on
          Maybe there is an error in the log
          Cheers,
          Bob
            Will check this weekend and post log snippet here... thanks
            Regards,
            Andrew B.
              For some reason... can't get debug log to work
              Turned it on a week ago... log file really didn't grow.
              Upgraded to 2.0.95.0 this morning.
              Turned plugin off, deleted the log so that i would start from scratch...
              Turned plugin back on...
              Attached log has activity for first second after turning plugin back on... then nothing... been using palmpads, and tripping x10 motion sensors... but no update to log..
              Turned plugin off.. then back on...
              adds one line to the log
              09/23/2018 04:07:53:109 PM : v2.0.95.0 - **************** Debug Logging DISABLED at 9/23/2018 4:07:53 PM ****************
              then nothing...
              Also attached my config file.
              Any ideas or thoughts are appreciated.
              BLRF-Detailed.log.txt
              hspi_BLRF.ini.txt
              Regards,
              Andrew B.
                Can you check that you have done this
                https://forums.homeseer.com/forum/3r...-debug-logging
                Cheers,
                Bob
                  Nope... i will do so when i have access to machine.
                  Thanks..
                  Will report back when i get the log working
                  Regards,
                  Andrew B.
