Re Connection failures
Hi Greig,
Quote
Is it using a usb hub?
Yes both the board are running off an internal hub, I have run out of usb ports on the machine.
Quote
Check the usb power settings the port may be sleeping.
checked all possible USB ports and none were set to sleep, I have also checked the BIOS, to be on the safe side I have set the PC to maximum power usage. The only thing that sleeps now is the monitor after 5 minutes.
I am at a loss as to know why this is happening, the software by the way is Win 7 64 bit home premium if that is of any help. I did think that may be as a last resort I could use an ethernet shield but do not feel overly confident about that.
Thanks for the pointers.
Peter
Hi Greig,
Quote
Quote
Peter
