I would love to see a plugin for interfacing with the devices from ControlByWeb. In my case specifically with their X-600M Web-Enabled I/O Controller. Although I suspect a Plug-In could be universal across their product line.
Their products provide monitoring analog & digital inputs and controlling built in high/low current relays.
They seem like a perfect complement/match to HomeSeer.
Below is a snippet from their Overview page.
Dennis
The X-600M is a web-enabled I/O controller that performs control, logic, and monitoring functions similar to that of a Programmable Logic Controller (PLC). However, unlike a PLC, the X-600M is designed for web based applications from the ground up. The X-600M can be setup, controlled, and monitored using its built-in web server and a standard web browser. The setup web pages are intuitive and easy to use and do not require special programming skills. No add-on software is required.
