Devices not working
    Devices not working
    I'm running HomeSeer on an RPi 3 with an Omni Pro II panel.
    I got the plugin to connect and it imported my units devices, etc., fine.
    I could operate lights and thermostats via the web interface the HS Touch app and through Alexa with both HomeSeer Skills.
    With those tests satisfactory I sat out to fine tune my device list.
    I spent all day configuring my Omni devices. Renaming them in full English, giving them proper voice command names, etc.
    None of my devices work now. I can't control them from the webpanel, Alexa, nothing.
    I rebooted the RPi and the devices are still listed there, with my changes.
    I stopped and restarted the Omni plugin.
    It properly connects to the panel and imported the devices. But all of the devices and units are red in the Omni Plugin.
    If I turn the check to green it creates a new device.
    In the Device Management area that new device operates correctly, but the existing device, the one with the edited name does not. The Omni Q Code number info are different in both instances.
    I can edit the new name to make it match the existing one and it still operates. I assume the Q info needs to be identical. I changed it and the old one still doesn't work.
    So something caused the existing list to be unrecognized.
    With all the work I put in today, I do not look forward to recreating every device from scratch.
    Is there a way to reinitialize these devices without losing all of the customization?
    Or is there a file on the RPi I can edit rather than going through the web interface?
    Update.
    I changed ONE unit.
    I replaced it with a new iteration, and it seems to have reinitialized the entire group.
    I am cautiously optimistic.
    ETA
    Apparently I'm just impatient.
    After rebooting the RPi it takes several minutes to reconnect all devices from the Omni to Homeseer.
    When I first go to the units section in the plugin, they're all off (red). If I wait a bit they start to turn on (green) one by one.
