Option is greyed out but should not be?
Hello,
At the time I released this plug-in, I was unable to figure out how to set the default records per page. I completely forgot I had it disabled in the options. I'll add this back to my queue and will give it another shot.
Regards,
UltrajonesPlug-ins: UltraMon, UltraM1G, UltraCID, Ultra1Wire, UltraLog, UltraWeatherBug, UltraPioneerAVR, UltraGCIR
Regards,
Ultrajones
Regards,
Ultrajones
Also -
I have noticed that even through I have the log retention (for HS Log) set at 12 Months - 5000 records is the maximum it will save. Bummer cause I didn't verify the behavior at first. I now have limited history.
Originally posted by Monk View PostGetting closer to fix?
Also -
I have noticed that even through I have the log retention (for HS Log) set at 12 Months - 5000 records is the maximum it will save. Bummer cause I didn't verify the behavior at first. I now have limited history.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
The 5,000 record limit is a display limit and not a limit of what's stored in the database. You should narrow down your search if you're hitting the 5,000 display limit.
Regards,
Originally posted by Ultrajones View PostThe 5,000 record limit is a display limit and not a limit of what's stored in the database. You should narrow down your search if you're hitting the 5,000 display limit.
Regards,
UltrajonesHS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Regards,
Ultrajones
