I installed the jvCaddx plugin (tried all versions, all produce the same results, i'm currently on 1.4.79.149), running HS2 2.5.0.81. I have run the connection verification scripts here, and they show a good solid connection with no errors or issues. The setup was pretty straight forward and I didn't have any problems, only when I get to the "Get Zone Names from Panel" part, it comes back with no zone names. The debug files show:
9/16/2013 2:58:01 PM...jvCaddx Plug-In Com~~!~~SendRequestToPanel()- Requesting =
022300254C
9/16/2013 2:58:02 PM...jvCaddx Plug-In Com~~!~~Data Received is 011C1D1E
9/16/2013 2:58:02 PM...jvCaddx Plug-In Com~~!~~Processing message 1C
9/16/2013 2:58:02 PM...jvCaddx Plug-In Com~~!~~Message command/request failed = 011C1D1E
9/16/2013 2:58:03 PM...jvCaddx Plug-In Com~~!~~SendRequestToPanel()- Requesting =
01212223
9/16/2013 2:58:03 PM...jvCaddx Plug-In Com~~!~~Data Received is 0B01352E3338F20DFA1D5FFC4F58
9/16/2013 2:58:03 PM...jvCaddx Plug-In Com~~!~~Processing message 01
022301264D
9/16/2013 2:58:04 PM...jvCaddx Plug-In Com~~!~~Data Received is 011C1D1E
9/16/2013 2:58:04 PM...jvCaddx Plug-In Com~~!~~Processing message 1C
9/16/2013 2:58:04 PM...jvCaddx Plug-In Com~~!~~Message command/request failed = 011C1D1E
9/16/2013 2:58:05 PM...jvCaddx Plug-In Com~~!~~SendRequestToPanel()- Requesting =
022302274E
9/16/2013 2:58:06 PM...jvCaddx Plug-In Com~~!~~Data Received is 011C1D1E
9/16/2013 2:58:06 PM...jvCaddx Plug-In Com~~!~~Processing message 1C
9/16/2013 2:58:06 PM...jvCaddx Plug-In Com~~!~~Message command/request failed = 011C1D1E
9/16/2013 2:58:07 PM...jvCaddx Plug-In Com~~!~~SendRequestToPanel()- Requesting =
022303284F
9/16/2013 2:58:08 PM...jvCaddx Plug-In Com~~!~~Data Received is 011C1D1E
On a related note, the device "Last Zone Faulted" never gets an event, so it perpetually stays in "Never set" mode, so i have no way of getting zone faults.
Attached is a zip containing my log files, and a pdf with screenshots of the various relevant pages.
If anyone could advise on a solution I would greatly appreciate it.
Thanks in advance!
Darren
022300254C
01212223
022301264D
022302274E
022303284F
Thanks in advance!
Darren
