IPThermostat plugin Information
    This plug-in is designed to allow HomeSeer to interface with IP Based Thermostats.
    Support for the following thermostats:
    - Proliphix NT and IMT series
    - Essent / ICY thermostat
    - Honeywell EvoHome and Round connected
    - Plugwise ANNA thermostat
    For more information goto here
    Version 3.0.0.0 Initial release.
    Version 3.2.0.0
    • Added support for the Honeywell EvoHome and Honeywell Round connected
    • Added support for HS3 Linux versions, except for the Honeywell thermostats because of extended JSON support not available on MONO.
    • Add support for setting direct heatpoint temperatures
    • Several bug fixes
    • Multi Instance support
    Version 3.3.0.0
    • Multiple HS devices per thermostat (For ICY/Essent and Proliphix)
    • Added more status HS devices for Proliphix thermostats
    • Several bug fixes
    Version 3.4.0.0
    • Plugwise ANNA thermostat support
    • Solved an issue with Honeywell thermostats which was encountered by a number of users!
    • Several bug fixes
    Version 3.4.5.0
    • Several bug fixes due to Honeywell API changes
    • Had to remove the mode function from the Honeywell thermostat because the API does not support it anymore.
    To upgrade, it's best to disable the plugin first. I've seen several occasions where the upgrade did not work due to the fact the plugin .exe was in use.
    Last edited by Rien du Pre; April 25, 2017, 05:50 AM. Reason: Version 3.4.5 available
    Rien du Pre
    The Netherlands
    Using:
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
