So far, I love the plugin. It is by far one of the most easy to use and setup I've come across in a while. I have noticed a few "glitches," though. I wanted to see if you are aware of them, or if they are limited to my setup.
1. Log entry: "error sending on command!" or "error sending off command!"
it still controls the device, however, just doesn't think it did, and the device status in HS doesn't change, even though the actual physical device status does change.
2. inability to rename devices. If I change the device name from "Speaker-5" for instance to "master bedroom" then the above log error is still true, except it isn't able to affect the status of the physical device.
Ian
Ian
