SUMMARY:
Using a Smarthome 2413S with HomeSeer 2.5.0.4 and Insteon Plugin 1.5.2.0 OR 1.4.2.0, I can't get HomeSeer to send X10 Preset Dim commands correctly.
- HS Version: 2.5.0.4
- Insteon Plugin Version: 1.5.2.0 or 1.4.2.0
- Error occurred: X10 Preset Dim Commands don't work correctly
- Reproducible: Yes
There's a lot of detailed technical info below, getting into the bits and bytes of the PLM message protocol. Casual readers may want to skip, but hopefully, this detail will prove to be sufficient for the programmers to figure out what's going wrong. Thanks in advance for any help you can provide!
DETAILS:
I have a mostly X10 system. It is almost all SmartHome SwitchLinc X10 device based, with extensive scene programming in the various devices.
Long story short: I've ended up with the SmartHome 2413S, because my 1132 CU died, and then my 2414U died. Additionally many of my SwitchLincs have begun to die, and I wanted a path to Insteon, so the 2413S seemed like a good selection. (Side note: what is up with all of these SmartHome devices failing?!! Do other people see this as well?)
I'm using the 2413S with the free 1.4.2.0 plugin. HomeSeer can successfully send X10 On and Off commands to trigger various scenes, but I've found that I can't send "Preset Dim" commands from HomeSeer to the X10-based Switchlincs correctly. If I try to send any dim value between 50 and 100% (16 to 31), Homeseer instead sends a Preset Dim to 0% and the light turns off. If I try to send any dim value between 0 and 48% (0 to 15), Homeseer instead sends a Preset Dim to 51.6% and the light turns on to about half brightness.
I updated HomeSeer from 2.4.0.11 to 2.5.0.4. That didn't help. And I tried installing the new Insteon Plugin 1.5.2. That didn't help either. I've reverted back to 1.4.2.0
So I decided to look at the actual bytes being sent to the PLM controller to see if it was HomeSeer/Plugin/Computer screwing up, or if it was the PLM screwing up. Answer: it is HomeSeer/Plugin/Computer that is screwing up. They are sending the wrong command data to the PLM.
Here's a couple of pieces of the log file with comments
This first log snippet shows what happens when I use the Homeseer Status window to set the dim level of device C1 to 40%. The results are the same for the 1.4.0.11 and the 1.5.2.0 Insteon PLM plugins
12/25/2010 4:44:30 PM ~!~Insteon~!~Queueing X10 Command: C1 Cmd: 10 Pcnt: 12 Data1: 0 Data2: 0
12/25/2010 4:44:30 PM ~!~Insteon~!~Preset DIM level 12
12/25/2010 4:44:30 PM ~!~Device Control~!~Device: Brooks OfficeBrooks Office Light Preset Dim Level 12 [40%]
12/25/2010 4:44:30 PM ~!~Insteon~!~Sending command 02 63 26 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 4:44:30 PM ~!~Insteon~!~..Got RF PLM Response 02 63 26 00 06
12/25/2010 4:44:30 PM ~!~Insteon~!~Sending command 02 63 0B 80 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 4:44:31 PM ~!~Insteon~!~..Got NAK from the RF PLM for command
12/25/2010 4:44:31 PM ~!~Insteon~!~..Retry #1 required. Pausing 250ms for RF PLM to clear...
12/25/2010 4:44:31 PM ~!~Insteon~!~..Got RF PLM Response 02 63 0B 80 06
As you can see, the third byte in the last command is 0x0B, which represents a preset dim value of about 51% (half bright). The same 0x0B value is sent for ANY dim level requested via Homeseer between 0% and 48% (0-15)
The correct third byte for the dim level of 40% (12) should have been 0x3D instead of 0x0B. Here is the correct transmit sequence:
02 63 3D 80
This next log snippet shows what happens when I use the Homeseer Status window to set the dim level of device C1 to 90%. The results are the same for the 1.4.0.11 and the 1.5.2.0 Insteon PLM plugins
12/25/2010 4:47:22 PM ~!~Insteon~!~Queueing X10 Command: C1 Cmd: 10 Pcnt: 28 Data1: 0 Data2: 0
12/25/2010 4:47:22 PM ~!~Device Control~!~Device: Brooks OfficeBrooks Office Light Preset Dim Level 28 [90%]
12/25/2010 4:47:22 PM ~!~Insteon~!~Preset DIM level 28
12/25/2010 4:47:22 PM ~!~Insteon~!~Sending command 02 63 26 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 4:47:22 PM ~!~Insteon~!~..Got RF PLM Response 02 63 26 00 06
12/25/2010 4:47:22 PM ~!~Insteon~!~Sending command 02 63 0A 80 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 4:47:23 PM ~!~Insteon~!~..Got NAK from the RF PLM for command
12/25/2010 4:47:23 PM ~!~Insteon~!~..Retry #1 required. Pausing 250ms for RF PLM to clear...
12/25/2010 4:47:23 PM ~!~Insteon~!~..Got RF PLM Response 02 63 0A 80 06
As you can see, the third byte in the last command is 0x0A, which represents a preset dim value of 0%. In other words, the light turns off. The same 0x0A value is sent for ANY dim level requested via HomeSeer between 52 and 100% (16-31)
The correct third byte for the dim level of 90% (28) should have been 0x3B instead of 0x0A. Here is the correct transmit sequence that should have been sent:
02 63 3B 80
Also note that there appears to be another bug. Each sequence above indicates a NAK from the RF PLM. I looked at the data stream from the PLM using a Serial Port monitor program, and HomeSeer (or the Insteon Plugin) is inadvertantly sending two extra Start of Message bytes between the House/Unit transmission and the Preset Dim transmission. These both cause a NAK (0x15) from the PLM. Here is the sequence sent & Received when using Homeseer to request a preset dim level of 40% for C1:
Sent: 02 63 26 00 HCUC: C1
Rcvd: 02 63 26 00 06 Response with acknowledgement
Sent: 02 SOM
Sent: 02 Second SOM (error)
Rcvd: 15 NAK acknowledging the error. Second SOM value is not allowed
Rcvd: 15 Another NAK. I'm not sure if this occurs here or after sending the next message
Sent: 02 63 0A 80 Preset Dim message indicating to go to 51% (16) brightness. Should be 40% (12)
Rcvd: 02 63 0A 80 06 Response with Acknowledgement
So, I don't know if the problem is with HomeSeer or with the Insteon PLM plugin. But I do know I never had this problem when using other controllers, including the 1132CU and the 2414U. Its only with the 2413S.
Any help is appreciated. And I'm willing to buy the 1.5.2 plugin if it can be fixed to resolve this problem.
Stripped down Insteon Error Report Log is shown below (Forum says I'm not allowed to post an attachment, or I would have done that).
INSTEON ERROR REPORT --------------------------------------
12/25/2010 6:18:28 PM - Queueing X10 Command: C1 Cmd: 10 Pcnt: 0 Data1: 0 Data2: 0
12/25/2010 6:18:28 PM - Preset DIM level 0
12/25/2010 6:18:28 PM - ResourceMananger::RequestExclusive for Resource 1
12/25/2010 6:18:28 PM - Sending command 02 63 26 00 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:28 PM - ResourceMananger::ReleaseExclusive for Resource 1
12/25/2010 6:18:28 PM - Sending command 02 63 0B 80 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:28 PM - ..PLM NAKed our STX, retrying without penalty...
12/25/2010 6:18:28 PM - ..Retry required. Pausing 250ms for PLM to clear...
12/25/2010 6:18:29 PM - Sending command 02 63 0B 80 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:29 PM - ..PLM NAKed our STX, retrying without penalty...
12/25/2010 6:18:29 PM - ..Retry required. Pausing 250ms for PLM to clear...
12/25/2010 6:18:29 PM - ResourceMananger::ReleaseExclusive for Resource 1
12/25/2010 6:18:39 PM - Queueing X10 Command: C1 Cmd: 10 Pcnt: 3 Data1: 0 Data2: 0
12/25/2010 6:18:39 PM - Preset DIM level 3
12/25/2010 6:18:39 PM - ResourceMananger::RequestExclusive for Resource 1
12/25/2010 6:18:39 PM - Sending command 02 63 26 00 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:39 PM - ResourceMananger::ReleaseExclusive for Resource 1
12/25/2010 6:18:39 PM - Sending command 02 63 0B 80 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:39 PM - ..PLM NAKed our STX, retrying without penalty...
12/25/2010 6:18:39 PM - ..Retry required. Pausing 250ms for PLM to clear...
12/25/2010 6:18:45 PM - Queueing X10 Command: C1 Cmd: 10 Pcnt: 31 Data1: 0 Data2: 0
12/25/2010 6:18:45 PM - Preset DIM level 31
12/25/2010 6:18:45 PM - ResourceMananger::RequestExclusive for Resource 1
12/25/2010 6:18:45 PM - Sending command 02 63 26 00 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:45 PM - ResourceMananger::ReleaseExclusive for Resource 1
12/25/2010 6:18:45 PM - Sending command 02 63 0A 80 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:45 PM - ..PLM NAKed our STX, retrying without penalty...
12/25/2010 6:18:45 PM - ..Retry required. Pausing 250ms for PLM to clear...
12/25/2010 6:18:46 PM - ..PLM NAKed our STX, retrying without penalty...
12/25/2010 6:18:46 PM - ..Retry required. Pausing 250ms for PLM to clear...
12/25/2010 6:18:46 PM - Sending command 02 63 0A 80 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:18:46 PM - ResourceMananger::ReleaseExclusive for Resource 1
12/25/2010 6:19:00 PM - Queueing X10 Command: C1 Cmd: 10 Pcnt: 9 Data1: 0 Data2: 0
12/25/2010 6:19:00 PM - Preset DIM level 9
12/25/2010 6:19:00 PM - ResourceMananger::RequestExclusive for Resource 1
12/25/2010 6:19:00 PM - Sending command 02 63 26 00 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:19:00 PM - ResourceMananger::ReleaseExclusive for Resource 1
12/25/2010 6:19:00 PM - Sending command 02 63 0B 80 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:19:00 PM - ..PLM NAKed our STX, retrying without penalty...
12/25/2010 6:19:00 PM - ..Retry required. Pausing 250ms for PLM to clear...
12/25/2010 6:19:01 PM - Sending command 02 63 0B 80 to PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/25/2010 6:19:01 PM - ..PLM NAKed our STX, retrying without penalty...
12/25/2010 6:19:01 PM - ..Retry required. Pausing 250ms for PLM to clear...
12/25/2010 6:19:01 PM - ResourceMananger::ReleaseExclusive for Resource 1
12/25/2010 6:46:36 PM - ***:Forced error / log generation
--------*End Pre-Error Log*--------------
--------*Start C:\Program Files\HomeSeer HS2\Config\Insteon.ini*--------------
[Config]
MaxHops=2
NumRetries=5
WaitTimeout=3
DetailedLog=3
DoCleanups=1
GroupBaseCode=[
LastInterfaceAddress=13.21.82
DeviceLocationFilterIndex=0
NumDevices=1
DeviceBaseCode=[
UseLocation2=0
DisablePolling=0
[Device 1]
DeviceID=00.75.82
DeviceName=Tap-Added ControLinc V2 0
DeviceLocation=Unknown
PollingInterval=0
DeviceType=0004
FirmwareVer=22
DatabaseDelta=-1
LinksDownloaded=0
EEValues=
LastContact=12/25/2010 6:12:29 PM
TotalInteractions=5
FailedInteractions=5
Protocol=1
[Device 2]
DeviceID=0A.BB.3D
DeviceName=Tap-Added LampLinc V2 2-Pin 1
PollingInterval=0
DeviceType=0106
FirmwareVer=32
DatabaseDelta=-1
LinksDownloaded=0
--------*End C:\Program Files\HomeSeer HS2\Config\Insteon.ini*--------------
SUMMARY:
- Reproducible: Yes
DETAILS:
02 63 3D 80
02 63 3B 80
Sent: 02 SOM
[Config]
MaxHops=2
NumRetries=5
WaitTimeout=3
DetailedLog=3
DoCleanups=1
GroupBaseCode=[
NumDevices=1
DeviceBaseCode=[
UseLocation2=0
DisablePolling=0
[Device 1]
DeviceID=00.75.82
PollingInterval=0
DeviceType=0004
FirmwareVer=22
DatabaseDelta=-1
LinksDownloaded=0
EEValues=
TotalInteractions=5
Protocol=1
[Device 2]
DeviceID=0A.BB.3D
PollingInterval=0
DeviceType=0106
FirmwareVer=32
DatabaseDelta=-1
LinksDownloaded=0
