LINUX IS NOT CURRENTLY SUPPORTED!
Fixes/Changes:
- HSEvent errors on startup...I'm having trouble reproducing the error; so this is just a shot in the dark related to AppStarting. (3.0.3.13)
- X10Settings error when controlling an x10 device (3.0.3.13)
- x10 devices have the on/off btns backwards; (3.0.3.14) - you might need to delete and recreate the device to get the on/off btns in the right order
- fixed X10Settings error
- The Insteon tab (for x10 config) on the device config page is removed if the device is an Insteon device. (3.0.3.14)
- Triggers for KPL Btns and Interface (3.0.3.16) Please resave Interface triggers to update internal values.
- X10Event string to integer conversion exception (3.0.3.17)
- LastContact dates saved in ini (3.0.3.17)
Enhancements
- Added Enable X10 option to config page. X10 users must enable this. Its disabled by default. Only enable if you are using the PLM for X10. If you are using another X10 plugin, please disable this option. (3.0.3.17)
Known issues:
- Other issues related to GenPage or Object is Nothing are related to the plugin crashing or disconnecting from HS3.
To Install:
1. Shutdown HS
2. Backup your current hs database and insteon.ini
3. Copy all the DLLs in the zip to the homeseer folder
4. Restart HS
For Migration from HS2
Copy your config\insteon.ini to the hs3 config folder
I recommend running HS 3.0.0.54
X10 User Instructions:
You must create the hs devices on the hs device management page using the Add Device button. Enter the Code (eg A1) only, don't bother with the Address field or the Device Type field, that will be populated as "Insteon X10".
You will see an extra tab labeled Insteon.
There are three options on the Insteon tab:
1. Supports Dimming (as opposed to just on & off). this will add a slider to the hs device for dimming control.
2. Support Preset Dimming (typically Smarthome x10 devices)
3. Supports Status Requests (typically 2-way devices)
select the appropriate ones per the physical x10 device.
Click the "Save as Insteon X10" button to save the device as an X10 device that will be controlled by the Insteon Plugin.
you may edit these values later and use the Done button on Insteon tab
If for some reason, you already created a bunch of x10 devices, you may use the "Update X10 Devices" on the plugin config page to assign any hs device that have a valid x10 code to the plugin. Then use the device management page to configure the device.
Starting with 3.0.3.17, you must Enable X10 on the plugin config page otherwise X10 msgs are ignored.
Enjoy!
Fixes/Changes:
Enhancements
Known issues:
To Install:
1. Shutdown HS
4. Restart HS
Enjoy!
