revisit the other thread and try one of the versions there then setup the script accordingly
change % in runtime
Mark
HS3 Pro 4.2.19.5
Originally posted by ez1976 View PostBut isnt the script for HS2 and not HS3?Mark
HS3 Pro 4.2.19.5
Originally posted by mnsandler View Postis the device saving your settings? when you reread links and settings do the same settings get get read back in?
i just want to see the log entries when you activate the few settings i mentioned
This morning a settings that opens up shades only at 10% didn't work and only 20% opened it to what was 10% the previous evening.
So I did a re-read of the device settings and links on that device only.
After that the 10% was back to normal.
Does this help?
Originally posted by ez1976 View Postsorry but i may be blind.
where is the 3.0.5.5 posted? all i see is 3.0.5.4
hs.runscriptfunc "Insteon", "", "SetDeviceSyncLinkedDevices", Nothing)Mark
HS3 Pro 4.2.19.5
but what about the vb file where i put the ID of the devices to set the sync checkbox?
otherwise i get this
Error Exception handling event action ACTION SCRIPT for event z_Generic Events Sync Responder Checboxes: Illegal characters in path.
Event Running script statement immediately: &hs.runscriptfunc "Insteon", "", "SetDeviceSyncLinkedDevices", Nothing)
the previous command you posted was "hs.runex("setlinked.vb", "main", Nothing)"
isnt there a ( missing ?
ok. i'm getting myself confused with running the script vs call the plugin function in HS3
put script setlinked.vb into \scripts folder
Code:sub main(parms as object) hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"aa.bb.cc", True}) hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"xx.yy.zz", True}) rem replace aa.bb.cc with an insteon id, add additional lines with the other Insteon IDs end sub
run the script with the following command:
hs.runex("setlinked.vb", "main", Nothing)Mark
HS3 Pro 4.2.19.5
get this
Error Running script(2) &hs.runex("setlinked.vb", "main", Nothing), init error: Object doesn't support this property or method: 'hs.runex'
the vb file is now:
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"1F.67.58", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"20:32:BF", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"24.EF.A8", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"2B.2A.80", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"29.43.00", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"20.1B.A9", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"1F.DF.7B", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"20.1B.E3", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"30.64.E0", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"20.32.62", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"22:CB:BC", True})
hs.PluginFunction "Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"20:32B", True})
end sub
why did hst change the basics?
try this:
hs.runscript("setlinked.vb", true, true)Mark
HS3 Pro 4.2.19.5
never boring
17:08:53 Error Compiling script setlinked.vb: End of statement expected.
נוב-02 17:08:53 Error Compiling script setlinked.vb: Method arguments must be enclosed in parentheses.
נוב-02 17:08:53 Error Compiling script setlinked.vb: End of statement expected.
נוב-02 17:08:53 Error Compiling script setlinked.vb: Namespace or type specified in the Imports 'System.Core' doesn't contain any public member or cannot be found. Make sure the namespace or the type is defined and contains at least one public member. Make sure the imported element name doesn't use any aliases.
two fixes:
1. Main must be capitalized
2. add an open paren after pluginfunction like the following:
I tested this it should work
sub Main(parms as object)
hs.PluginFunction("Insteon", "", "SetDeviceSyncLinkedDevices", new object() {"1B.9B.F1", false})
end sub
call with
&hs.runscript "setlinked.vb", true, trueMark
HS3 Pro 4.2.19.5
Originally posted by ez1976 View Postworks great!!!
should i schedule to run once a day?Mark
HS3 Pro 4.2.19.5
