Multiple Trigger Phrase in one Handler?
    #31
    I can add a homeseer command for waitsecs if you need one
    If this is not what you want give me an example of you are trying to do
    Cheers,
    Bob
      #32
      Yes that would be great ! Thank you
        #33
        Download the same zip from the link I posted above
        Build will be 3.0.15.0
        You can now use:
        HS[WaitSecs~2]
        Cheers,
        Bob
          #34
          You can now use:
          HS[WaitSecs~2]
          it works thanks !
            #35
            Originally posted by hjk View Post
            3. Command: HS[RunScript~ReservationScript.vb~Main~%EVENTNAME%]
            4. A script that you create, called "ReservationScript.vb", then takes EVENTNAME (which in this case is "R3941656 Luke Skywalker") and performs a regular expression on it to extract the last 4 digits of the number, then calls BLLock by script to set the lock: hs.PluginFunction("BLLock", "", "EnableLockUser", New Object(){660,1}) --- or whatever the scripting call is to set a lock code.
            @hjk I'm at loss when it comes to VBscripting or coding. I do however manage to get by with some help and instructions. I understand the part "3. Command: HS[RunScript~ReservationScript.vb~Main~%EVENTNAME%]" and that I should create a vbscript in the HS3 scripts folder and that HS3 will execute this script, but "4. A script that you create, called "ReservationScript.vb" I'm at loss. Can you or someone please give me a working example of such a script? The script must take into consideration that it shall only trigger/continue on events where there exist "R+7 digit number" so if there is an event with name "R&R" it will exit and not continue.
            @Blade: In order for my events with "R+7 digits number" to trigger the handler, the Trigger Phrase function must support wildcards. Is this something that also can be supported? Also the bug with not being able to deselect all Calendars after one or more calendars has been selected is still there in version 3.0.15.0 (just so you don't forget :-)
              #36
              I have fixed the saving for calendar ids in 3.0.16
              I still need to figure out how I am going to add the ability to search for R#######
              I wrote this script but have not tested it:
              This assumes that your lock root device ref is 660 and the pin location you want to add the user to is 1
              If this was used as an example:
              The lock code would be 1656 and the user name for the lock pin would be "Luke Skywalker"
              Note: You will need BLLock 3.0.13 for this to work (which I have submitted to the updater)
              Sub Main(ByVal eventName As String)
              	Dim splitArray As String() = eventName.Trim.Split(" ")
              	If splitArray.Length = 3 Then
              		Dim reservationNumber As String = splitArray(0).Trim
              		Dim userName As String = splitArray(1).Trim & " " & splitArray(2).Trim
              		reservationNumber = reservationNumber.Replace("R", "")
              		Dim lockCode As String = reservationNumber.Substring(reservationNumber.Length - 4)
              		If IsNumeric(lockCode) Then
              			hs.PluginFunction("BLLock", "", "AddUserCodePin", New Object(){660,1,Integer.Parse(lockCode),userName})
              		End If
              		lockCode = Nothing
              		userName = Nothing
              		reservationNumber = Nothing
              	End If
              	splitArray = Nothing
              End Sub
              Cheers,
              Bob
                #37
                I have attempted to add regular expression ability to the trigger phrase
                You will need to select the checkbox below the trigger phrase to select regular expression
                You could try the following regular expression for you R1234567 trigger:
                R\d{7}
                The saving of no calendars should be fixed as well
                Here is the build (3.0.16.0)
                http://www.bladeplugins.com/betas/HSPI_BLGData.zip
                1. Shutdown HS3
                2. Backup the existing HSPI_BLGData.exe
                3. Unzip the HSPI_BLGData.exe to the HS3 root folder and overwrite
                4. Restart HS3
                Let me know
                Cheers,
                Bob
                  #38
                  Installed version 3.0.16.0
                  What's working: saving of calendars
                  Not working: regular expression:
                  /R\d{7}/g
                  - the handler will not trigger if I create a new event with name: "R3941656 Luke Skywalker". Tested with all calendars unchecked and also the specific calendar checked.
                  Also I could not find BLLock 3.0.13 in the updater? Checked under Beta aswell. Only 3.0.11.0 under "Security"
                    #39
                    BLLock 3.0.13 is not there yet but has been submitted to HS for approval
                    Can you capture a debug log of the regular expression not working
                    Attach it zipped
                    Cheers,
                    Bob
                      #40
                      Here you go Blade, same password as b4
                      Created a brand new event:
                      R3441646 Luke Skywalker
                      Start:19.03.2018 06.50.00
                      End: 19.03.2018 06.51.00
                        #41
                        Can you try the trigger string like this:
                        R\d{7}
                        Cheers,
                        Bob
                          #42
                          The latest regex suggested by you will trigger on all events, but from all calendars of the user even if only one has been selected? Also it seem's to trigger several times? I know the drill now. Same password as b4
                            #43
                            Yes I do see it running more than once
                            It does seem to be different events that are triggering
                            I will check into that and let you know
                            Cheers,
                            Bob
                              #44
                              Try out 3.0.18 in the beta section
                              Cheers,
                              Bob
                                #45
                                3.0.18 installed and can confirm the handler will now trigger correctly by using the regex
                                R\d{7}
                                Now I would like to test this together with BLLock 3.0.13 and the vbscript you made to set the code of a lock, but I can't find this version in the updater. Can you provide a download link instead?
