Looking for quality outdoor motion sensor for remote locations, that are 300 to 600 feet from home.
I'm using DakotaAlert for few years now and I have mixed feelings.
1. The good
- reliable long range transmission (advertised 2500 ft. I'm using it up to 600)
- one receiver serves up to 4 zones (I'm using 2 receivers and 8 sensors)
- simple relay outputs at the receivers allow for easy seamless integration w/HS
2. The bad
- motion detection is really bad
- very short range of motion detection of 10-15 ft.
- misses motion detection even at short range
- battery hog - battery needs replacement every 6 mo. even at my low residential use of 2-3 activations per day
That's why I'm looking for better quality outdoor motion sensors to fit my application - 600' range and better battery life and motion sensing plus relay outputs at the receiver so that I can integrate with HS.
For those who like details I should add that I have currently 8 outdoors motion sensors, 2 receivers and I hook the relay outputs from the receivers to my DSC security panel and from there to HS. HS has very good plug-in for DSC. I'm looking to replace the existing and add more motion sensors. Due to the problems with Dakota, I'm reluctant to keep piling up Dakotas.
1. The good
2. The bad
