Hi, I'm very new to Z-wave.
My Setup is 10 Fibaro motion sensors gen 5 (FGMS-001) and Z-stick Gen 5 Z-wave (AEOEZW090-C)
The first registered sensor seems to work as it should I think but the rest are triggering motion/nomotion every x seconds even if no motion in the area.
I have put a camera in the room to stream if the motion sensor was blinking and the result is exacly every 30 seconds. This time is equal to same time settings as "Motion timeout (seconds):"
PHP Code:
Mar-05 15:44:14 Z-Wave Device: Node 16 Z-Wave Sensor Binary Reserved Set to On/Open/Motion
Mar-05 15:44:14 Z-Wave Device: Node 16 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: Motion Detected Unknown Location
Mar-05 15:44:13 Z-Wave Device: Node 16 Z-Wave Sensor Binary Reserved Set to Off/Closed/No Motion
Mar-05 15:44:13 Z-Wave Device: Node 16 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: No Event
Mar-05 15:44:10 Z-Wave Device: Node 18 Z-Wave Sensor Binary Reserved Set to On/Open/Motion
Mar-05 15:44:10 Z-Wave Device: Node 18 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: Motion Detected Unknown Location
Mar-05 15:44:09 Z-Wave Device: Node 18 Z-Wave Sensor Binary Reserved Set to Off/Closed/No Motion
Mar-05 15:44:09 Z-Wave Device: Node 18 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: No Event
Mar-05 15:43:57 Z-Wave Device: Node 16 Z-Wave Sensor Binary Reserved Set to On/Open/Motion
Mar-05 15:43:57 Z-Wave Device: Node 16 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: Motion Detected Unknown Location
Mar-05 15:43:56 Z-Wave Device: Node 16 Z-Wave Sensor Binary Reserved Set to Off/Closed/No Motion
Mar-05 15:43:56 Z-Wave Device: Node 16 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: No Event
Mar-05 15:43:40 Z-Wave Device: Node 16 Z-Wave Sensor Binary Reserved Set to On/Open/Motion
Mar-05 15:43:40 Z-Wave Device: Node 16 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: Motion Detected Unknown Location
Mar-05 15:43:39 Z-Wave Device: Node 16 Z-Wave Sensor Binary Reserved Set to Off/Closed/No Motion
Mar-05 15:43:39 Z-Wave Device: Node 16 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: No
