HS 1997 inconsistent X10 device name translation
    I have a motion detector at G1 called "Basement Motion Sensor." When everything is operating correctly, motion will log "G1 (Basement Motion Sensor) G On." However, sometimes I get "G1 () G On." If I open and save the device, it corrects itself. However, it was working right when I started HS, then mysteriously stopped working right.
    Any ideas?
    Joe
    Bueller? Anyone?
    Thanks.
      Same problem here
      I have the same problem.
      I have a personal 'quickview' which will frequently show a corrupt page. Its easy to spot where the error occurred, and if I go to that device, open the modify page and save the device (no changes) it corrects it!
      This is not only in 1997 - I believe its been there since 1984.
      Not much help to you but at leasy you know you are not the olny one.
      Rgds
      Ron
