Happy Thanksgiving Mark!
I have what I believe is a downstream issue from the refresh problem that was fixed in .147 of HS3. I added some additional new devices and the refresh issue cropped up, I did a refresh and it appears that that may have been the cause of some duplicate devices. I get an error message during boot up :
11/27/2014 10:58:48 AM ~!~Info~!~Plugin Insteon has connected. IP:127.0.0.1:56933
11/27/2014 10:58:49 AM ~!~Insteon~!~RF PLM contacted on COM4 with an Insteon address of 1C.F7.26 and firmware version 99
11/27/2014 10:58:50 AM ~!~Insteon~!~Error loading Device 22 from insteon.ini file. It has a duplicate Insteon Address 2B.C6.20 which is already registered to Device 21
11/27/2014 10:58:50 AM ~!~Insteon~!~Error loading Device 23 from insteon.ini file. It has a duplicate Insteon Address 2B.C6.20 which is already registered to Device 21
11/27/2014 10:58:50 AM ~!~Insteon~!~Time to load devices from ini: 0.495
11/27/2014 10:58:50 AM ~!~Insteon~!~Warning! The following device already exists in the Device List: 2B.C6.20
11/27/2014 10:58:50 AM ~!~Insteon~!~Waiting to initialize External Devices...
11/27/2014 10:58:51 AM ~!~Plug-In~!~Finished initializing plug-in Insteon
Attached is my ini file, is it safe to just edit out the dup?
Thank you so much,
Chris
Thank you so much,
Chris
